Driver Side Blend Door Actuator location 2015 Infiniti Q70S?
eyedeekay
Car: 2006 Infiniti m35
Has anyone replaced the driver side blend door actuator for either the 2011-2013 Infiniti M's or 2015-2019 Infiniti Q70's? I'm having a hard time finding where it is exactly online or in the service manuals. I see plenty of info for the Q50 but not q70. Thanks!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
See page HAC-130 here:
https://www.nicoclub.com/service-manual ... %2Fhac.pdf
All 5 of the servos call for removing the whole HVAC Unit. I don't know if that's right, you might be able to just remove the dashpad, but it looks like a big job no matter how you cut it.
eyedeekay
VStar650CL wrote:
Mon Nov 03, 2025 8:58 am
Okay so I looked at all three actuators on the left side and they seem to be actuating fine. The primary actuator on the left that actuates between heating and cooling is thankfully accessible from the underside.
Im starting to think maybe its a AC charging issue? The air blowing is not necessarily hot, it is just not as equally cold as the right side, which is truthfully not even that cold either. THe heater works as intended for both the left and right side of the AC vents
I only just started looking to this BTW becdause the car has been sitting for nearly 3 months due to being away from work.
VStar650CL
Technical Expert
The driver side on most Nissan products will get warm first if the A/C is undercharged. So your surmise may well be correct.
eyedeekay
VStar650CL wrote:
Mon Nov 03, 2025 12:06 pm
This ended up being in the issue, charged up the AC and now it blows cold AC, thanks for the guidance help Vstar! Now I have to add the dye in the system to figure out where it's leaking from.
VStar650CL
Technical Expert
:dblthumb:
