stumpz wrote:ahhhhh i've finally narrowed my problems down to my timing. i believe the correct term for what my engine was doing is 'misfiring' creating that 'puh' sound out of the exhaust like it's trying to start. tomorrow morning that ish should be running..if not then i have no idea what else to do. When i'm getting the timing chain in the correct position, which way do i turn the crankshaft? My chilton's (biggest waste of 20 bux) does not specify and it might be dif for the sr. i pulled my CAS out and i do not have a yellow or orange dot, but i still think i can go by the phase2motortrend and/or the one on heavy throttle. wish me luck tomorrow!
woah, sorry dude. i thought you meant ignition timing, not valve timing.IvoryJ30t wrote:go buy a timing light.
