bleh need SAFCII help..
Nightstalker
Car: 2007 Toyota X-Runner
1993 Toyota MR2
1989 Toyota MR2 S/C
1989 Nissan 240sx
I know there is a thread somewhere on KA-T.org on the safcII setting but i cant find it so don't know if this is in there. I hooked all the wires up correctly and everything but i am confused about the cylinder and throttle settings. I have it set to 4cyl and the arrow pointed up right. I was also reading in the manual about "Self learning the throttle angle" and it say to make sure it says 0% at first and mine definatly says 58.3% and climbs up to 100% slowly.
Now what i want to know is how do i get the throttle angle down to 0% and stay there inless i actually give it gas, are my cyl and the arrow correct?
This is on a fully stock '93 KA24DE.
Thanks in advanced!
Nightstalker
1993 Toyota MR2
1989 Toyota MR2 S/C
1989 Nissan 240sx
mm bump, anyone?
180fan
Car: 89 fastback
a bump 2 hours and 30 minutes later is uncalled for, it probably didn't even move half way down the page.
now with that said, why did you bother with an afc on a bone stock engine?
foCk
Either you didnt wire the safc up correctly, its not on the right tps setting or your throttle is stuck
Nightstalker
1993 Toyota MR2
1989 Toyota MR2 S/C
1989 Nissan 240sx
i put it on cause im going turbo soon, and i bumped it 2hrs and 30min cause i bumped it before i went to bed. My throttle isnt stuck either..
