bleh, 240sx problem...ngk spark plug gap on 89 240sx?
comablack783
i did a tune up(oil, filter, spark plugs) on my car like 2 weeks ago and its been running odd, like it feels slower, and im almost 99% sure it sucking up more gas, could this be do to improper gapping? whats the gap supposed to be set on NGK plugs for a 89 240sx (sohc)? i also put a lucas injector cleaner that that they recommend at advance discount, pretty pricy for its size. the reason i say im losing gas milage is because the last time i filled up i put in 13.7 gallons and the tripometer said 242 miles, filled up this week and put in 14.8 (almost empty) and i only got 209 miles?... ergh...
180fan
Car: 89 fastback
1.0-1.1mm
comablack783
going to regap ASAP, will this fix my milage problem? or could that have been do to the injector treatment? it said 33% more gass milage blah blah blah... seems like its 33% less..ergh...
Axel Grungy
Car: 2001 G20 5spd
IIRC the ngk plugs should be pre-gapped, ive never gapped mine
silencer.1
Car: women, my car, paintball
FSM says to set the plugs at .039in - .043in. I think they come .044in out of the box.
tonynalli
you wouldnt happen to be interested in some ngk spark pug wires for your car, they were slightly used. if you are email me at [email protected]
