NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Sun Mar 21, 2004 1:52 pm
I think he means how do you bleed the air out of the system;)
most motors (for example the KA you used to have) have a bleeder screw to release air from it. I believe that this bleeder screw is at the top most point that the coolant flows through the system, allowing the air to collect here. You generally open this screw with the motor running until coolant flows out of it, leaving the system free of bubbles.
For the CA18 however, the highest point in the cooling system is the radiator cap (I THINK!), so IT acts as your bleeder.
Take off your radiator cap (make sure the motor is cool before you do this) and allow the car to run. While its running and heating up, keep adding water/antifreeze until it is topped off. Make sure you let it get hot enough to open the thermostat. I also added some water to my overflow tank to allow it to suck up extra if it needs it. Mine seems to be running fine using this method:)
Sean
