mechanicalmoron »
https://forums.nicoclub.com/mechanicalmoron-u183526.html
Fri Dec 14, 2012 10:05 pm
Helpful as that funnel looks, I fail to see how you think it will help you bleed anything.
The bleeder you speak of is not going to do much, because of it's location, even though I DID use it...
When you're filling things, already have the overflow tank topped off, and then once it's full, repeatedly rev the motor by twisting the tb, with the coolant cap off, and it will push the bubbles through, when you see no bubbles, and have topped it as much as you can, just before it overflows and in time that the cap pushes a little bit of coolant out, (maybe, I guess, long after it overflows, depending on how bad your bubbles are...., cap it. (it will suck any extra that it'll need as it cools out of the overflow tank.)
Other than that, if you really care, you could go buy a matching drillbit, tap, and screw/bold, and make a new air release hole.
