ARKQX33V6 wrote:Bleeder removes excess air in the system. Drop anti-freeze by removing lower rad hose and capture fluid, or use c*** at bottom of rad. There is a bleed on side of engine. Plug holes, return rad hose, fill rad leave top bleed open, fill rad to top, run engine to temp, keep filling rad let air out bleed, squeeze
I kratiated from skool last night so I do again
Bleeder used is for removing air especially when the cooling system is opened and air is allowed to enter.
When filling with a liquid water/antifreeze, often pockets of air are compressed in the coolant chambers inside the motor.
The compression exerted by the weight of water/ antifreeze puts only a slight compression factor onto these pockets of air.
While filling the radiator, more weight is added to the already compressed air and the already compressed air begins absorption into the coolant mixture.
With a full rad, leaving the top off, and leaving at least 1 of the bleeder holes loose, the hole at top higher than the actual cooling system but joined as part of the system. Pascal's rules soon apply as:
The engine is started and because 75% of the energy is wasted heat, soon the coolant becomes hot, Pascal's rules apply
Expansion
Thermodynamics, heat concentrates, hot moves to less hot, air compresses under heat and pressure.etc etc.
The small amount of air bubbles up to the biggest port of relief, the open rad cap and also to a lesser degree the open bleeder.
When you are satisfied the bigger bubbles have stopped close the rad cap but leave the bleeder open to finalize any smaller bubbles of air. The motor is up to temperature, the coolant is hot the bleeder is closed.
Now you have a closed, tight chamber with hot fluids.
Stop the motor, it cools.
Expansion that took place when hot, reverses and now contraction takes place. The liquid coolant reverses in size.
Attached to this enclosure is an overfill bottle with a cap. An expansion chamber!
Let the motor become cold, check that overfill addendum, there is a normal mark on it and in case there is no identification mark use about 1/3 the volumetric capacity as cold normal maximum fill line.
When cold that expansion chamber should have at least a visual of coolant in it, to the mark but no more. Because when the coolant heats up it expands and that chamber, expansion tank, is the only place within a rigid coolant chamber that can take the expanding heated coolant.
When hot that expansion chamber fills to its max line. So keep the fluids in and out of the expansion chamber at the correct level at hot and at cold temperatures.
Vehicles have drain cocks on their cooling system. With little use these small cocks or valves get stuck. Instead of using these drain cocks a coolant main hose at the lowest part of the system can be easily removed, drain and then re-attached. By using the rad hose lower you can feel, smell, look and examine the condition of the hose. Then replace as needed. The drain c*** is small, the rad hose is big...which do you think will drain faster?
And remember to capture the used coolant mixture, pets will drink it because it is sweet tasting, teen age people have been known to drink it...it is very very dangerous to mammals with eyes and kidneys...it will destroy kidneys and it will make you blind. No repair, no replacement.
It is a hazardous waste and must be collected, safely stored and disposed correctly.
