jmancini »
https://forums.nicoclub.com/jmancini-u3421.html
Sat Dec 07, 2002 9:51 am
This seems like such a simple procedure, but its causing me some serious grief! Is there a secret to successfully bleeding the 240sx hydraulic clutch?
I've been following the FSM procedure multiple times now and I cannot seem to get it right - the clutch won't disengage! I had a friend pump the clutch pedal 4-5 times, hold it to the floor, then open the bleeder screws on the damper, then repeat again multiple times. Then did the same thing bleeding it at the slave. The slave cylinder is pushing the clutch lever. But when I start the motor, its clearly still in gear. I repeated this about 3 or 4 times. No luck.
Then I tried a vacuum pump attached to the bleeder screws, followed the same drill, and got the same result. Then I bypassed the damper, connecting the master directly to the slave, bled it at the slave and still I can't get it to disengage.
The slave is brand new. I haven't replaced the master. Is there a way to tell if the master is bad? Car has about 106k on it.
Am I doing something wrong? Should I replace the master? (BTW, I bought the car in a non-running condition, so I don't know for certain that the clutch hydraulics were/weren't worn to begin with). Thanks...
