bleeding slave problems
dray3OOO
Car: 90 rb20 hatch HKS everythang
77 corolla stroke 2tg 40mm mikunis
im bleeding my brakes now i continue to pump and no pressure to the clutch still? any advice
Ramius83
Car: 1995 240sx SE
Ummm, what are you exactly trying to do? Bleed your brakes or bleed your clutch?
dray3OOO
my fault yea the clutch
Ramius83
Car: 1995 240sx SE
What was the reason for bleeding the slave cylinder? Did the clutch system just go out on you? Did you replace anything? Are you getting fluid shooting out when you open the bleeder with the pedal depressed?
dray3OOO
yea my clutch went flat so i figured the slave so i changed it but i bleed it until fluild was pouring out. but the clutch still flat and when i push it down it doesnt come back up\
RWP
When i replaced my master cylinder it took me about 22 hours over three days to fully bleed the clutch lines. Don't forget about bleeding the damper box as well as the slave Cylinder otherwise your doing a whole lot of nothing.
