Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Mon Nov 22, 2004 11:33 am
Get a buddy, have buddy pump clutch 6 times and hold in after 6th pump, open bleeder screw slightly till fluid comes out. At this point the clutch pedal will stay down and not pop back up. Just manual pull it up. Repeat till no more bubbles come out. Would be nice to have some sort of clear tubbing to fit over the nipple so you can visibly see bubbles comming out. Once no more bubbles is seen, you are done. Tighten up everything. Keep eye on resivoir to make sure it don't go empty.
