rc1honda »
https://forums.nicoclub.com/rc1honda-u103360.html
Sat Apr 02, 2011 8:09 pm
Yeah bleeding the hydo's can be difficult. I was going to ask you ho your oil pressure was. Usually wuth goos oil pressure the lifters will essentially bleed themselves. The only time i would suggest bleeding them is after a complete tear down and rebuild. Like when doing the head gasket, or when changing springs, and getting head work.
When bleeding all you have to do is remove the cams, and rockers. Then cut a pop can half, fill it with oil and take a small allen key and "pump" the top of the lifter while making sure the lifter stays in a upright position. Then when installing just make sure to keep them as upright as possible.
