2Fass240us »
https://forums.nicoclub.com/2fass240us-u23551.html
Fri Mar 18, 2005 4:06 am
1) Follow the FSM for valvetrain removal2) Take a bowl close to 10" round and 6" deep and pour 1-2 quarts of oil in it. I mentioned these dimensions because I used a coffee can, and it didn't have enough diameter for me to get both of my hands in.3) One by one, remove the HLA's and soak them in oil. Keeping it submersed the whole time, hold it upright with one hand and use a paperclip or other similarly-sized, strong metal piece to depress the ball check per FSM instructions. While you do this, pump the plunger until you can't press it down anymore.
I was able to remove my HLA's with oily hands, and reinstall them the same way, so I'm not sure why it takes pliers. If you do use pliers, take care not to damage the HLA. Make sure they're turned the same way when you put them back in, BTW.
I did this 2 weeks ago, and ended up needing some clarification on the bleeding process. I searched on FA and found some instructions that helped me understand a helluva lot better than the FSM did. Good luck!
-Andy
