silvsx »
https://forums.nicoclub.com/silvsx-u1831.html
Sun Dec 08, 2002 1:16 pm
did you bleed the clutch at the proportioning(sp) valve? if so, you may have had the same problem i did. I installed a clutch, and saw that my slave cylinder was dead. After replacing this and attempting to bleed the system, my master cylinder blew out. Finally, after some research I found that the clutch prop. valve is worthless and is prone to problems so I torched the fuc**r out and ran new clutch lines ..... that worked.
