own3d »
https://forums.nicoclub.com/own3d-u26108.html
Fri Apr 01, 2005 1:25 pm
ok, well i replaced my master cylinder since it was leaking and have had a hell of a time trying to bleed this thing. there is the bleeder valve on the junction block and another one on the slave cylinder. the one on the junction block is normal, i open it half a turn, push the pedal down and it shoots some fluid out, close it let up on the pedal. i did this 4-5 times and moved onto the slave cylinder bleeder. i open it push the clutch down, nothing comes out, so i close it, let up the clutch and try again, nothing, i tried probably 7-8 times and never got any fluid to come out of it. today i took the bleeder all the way out and the hole started dripping fluid but i looked at the bleeder and there was no hole anywhere on it for fluid to go through it? i am completely confused by this and i need to get this thing outta the garage, my dad is tired of parking outside.
