bleeding brakes with abs
240hybrid
i have an s14 and i need to bleed my brakes, there are no bleed nipples on my abs pump so i don't know how to bleed the pump. So do i just bleed the brakes regularly or is their a way to bleed the pump as well?:ylsuper
yellow_jacket
Car: 95 240sx
crack the fittings open and do it with the car off.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
You cn bleed it at the calipers. If its anything like an s13 abs, then there are bleeder valves on the abs unit under the hood, they just have caps covering them.
