Bleeding Brakes...Engine on or off?
Locknut
Car: 91 Q45
I thought I read a post a while back that said your car should be running when you bleed the brakes...any ideas as to why? Vacuum assist? Easier to get the air out? Abs pump?
BlueC
Car: 2000 Infiniti Q45t AE
I've never needed the engine running to bleed the brakes on any of my cars. A vacuum pump works very well to bleed the brakes, but you need an air compressor for that.
Bwana
Car: Denali
I've never heard of bleading brakes with the engine running, somehow it doesn't sound like a good idea to me, but I could be wrong...? I've always done it with the engine off.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you wont need the vacuum assist when the brakes are not really under pressure...
