Bleeding Brake
discusfa
I tried to bleed the brake system. After I was done, the brake pedal was still loose. Please help Thanks
180fan
Car: 89 fastback
how'd you bleed the system? which car? and did you try it again to check for leaks and or bubbles?
hotshot240sx
Car: my 240sx
when you bleed your brakes you must start from the furthest away from the master cylinder, that order goes: RR-LR-RF-LF. and make shure you bleed the system completley... "NO AIR"! and make shure your master never goes dry... i would hope you have checked for leaks on all your lines and from the master. so if all else fails you may have an internal issue within your master.
discusfa
i solve the problem thanks
