Bleeding After Caliper Rebuild
Khronik
Car: Pearl White - 91 N/A 2+2 Auto (RIP)
Arctic White - 96 N/A 2+0 5spd (SOLD)
Aztec Red - 90 TT 2+0 5spd (DD)
- Megan Racing DP's
- Borla Catback exhaust
- CZP ECU Upgrade
- SZ High 5 Clutch
Going to rebuild my front calipers due to a leak on the passenger
Naturally going to have to bleed the breaks, but is there anything else that needs to be bled after reinstalling?
robomatic12
Car: 1990 300ZX TT
ABS pump needs to be bled, do it according to the steps in the service manual which is available online if you google "300zx service manual"
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
^^Not on a '96. The ABS pump bleed points were removed in '94, IIRC.
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
Khronik wrote:Going to rebuild my front calipers due to a leak on the passenger
If you put a clamp on the flex line going to the caliper before you remove it, you will save yourself a lot of headaches. It will keep the system from draining and resulting air pockets. Then once you re-install the caliper, fill the master, and crack the caliper bleed screw (attach a hose to a bottle) and let it drip. This will remove most of the air. You should be able to rebleed the system quickly.
robomatic12
Car: 1990 300ZX TT
Ace2cool wrote:^^Not on a '96. The ABS pump bleed points were removed in '94, IIRC.
Good catch! I forgot to read OP's vehicle specs
