bleeding 93 Q45 brakes???? help
SUB ZERO CAR FANATIC
Car: 1993 Infiniti Q45 ( SOLD)
1997 Cadillac Deville Concourse
1998 Cadillac Seville STS
2009 Infiniti QX56 LE
I know there is talk about the procedure of bleeding the brakes onthe Q, dont think i heard a definite answer as how to do it, or maybe i mis-understood!I have done brakes a 100 times never had this complication.S0 can you not just pump pedal and bleed air/etc. out of bleeder valve on calipers? thats what im trying now, my pedal is going all trhe way to the floor after pumping and adding fluid 2 or 3 times? whats the clicking noise heard in shifter area each time i press pedal? does key need to be on? thanks for any help.
SUBZEROCARFANATIC
Denver90Q
Car: 1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
Have you bled the ABS pump?
Q45tech
Brakes haven't really changed much in 20-30 years other than ABS.
The best machine we ever bought was a BG brake vacuum unit uses shop air to suck out old while automatically refilling master cylinder.............connect to bleed screw let it chug chug for a few minutes then close the valve. Then move to another bleed valve...rear to front finally the abs pump valves................done in 15 minutes requiring no one pushing on pedal.................doubles - triples productivity.
Plus no mess as all used fluid is stored in a 10 gallon tank and a new liter is poured into system for each exchange and gratuated marks tell you when to move to the next valve.
Here's a used one for $750 but you'll have to do 100 per year to get a fast payback: We broke even in the first 6 weeks considering our labor rate!http://denver.craigslist.org/pts/594350777.html
How do you go about bleeding it! theres 2 bleeder valves if im correct,onefor front one for rear and one for either R front or L front,cant remember,well that makes 3,oh well you get the idea. thanks
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
SUB ZERO CAR FANATIC wrote:How do you go about bleeding it! theres 2 bleeder valves if im correct,onefor front one for rear and one for either R front or L front,cant remember,well that makes 3,oh well you get the idea. thanks
IIRC, the sequence for bleeding Q brakes is RL ("R" = Rear "L" = Left), RR, FR, FL.
For the acronymically challenged, that's Rear Left (Rear Driver's Side), Rear Right (Rear Passenger's Side), Front Right (Front Passenger's Side), and finally Front Left (Front Driver's Side).
Denver90Q
Same as for calipers.
http://www.nicoclub.com/FSM/
Denver90Q
Q45tech wrote:Brakes haven't really changed much in 20-30 years other than ABS.
I wonder if you could use it to replace your transmission fluid?
Also what does a brake flush do? Brakes Plus usually talks me into getting them!
