Bleeder Valve Location???
chiroengine
Car: 2002 Nissan Pathfinder, 2005 Nissan Murano
Can any body help me with the location of the coolant system bleeder valve onmy 2002 Pathfinder???
fueler
Car: 2 Nissan's
2 BMW's
Dont overlook - On 3.5L V6 engines, there is a secondary thermostat (called the water control valve) that can be accessed only after removal of the intake manifold - have you checked that? To answer your question, the bleed valve is at the rear of the engine. It is a 3/8" tube sticking up with a black rubber plug on the end of it. There is a sticker on the firewall behind it that says "do not open when hot"
chiroengine
Thank you for your response. I was afraid of that - the second thermostat.Is removing the intake manifold and replacing the secondary therm. a difficult job? I'll try to bleed the system first. Thanks fueler
chiroengine
Is it true that the system has to be hooked up to a vacuum in order to bleed or can I do it via ambient air?
