There is still air in the system, the only way to fix it is to keep bleeding untill all the air is out and the pedal returns on its own.kaedachef wrote:I bled my clutch dry since the fluid was black nd now my pedal wont disengage unless i pull it up manually. What can i do I didnt bleed it from the slave but from the other spot next to it on the rail. what can I do i have an important appointment at 5 pm and need this car. Its my only transportation.
