Bleah, 180k miles on my motor...
prigo
Compression is a bit high, friend said thats likely caused by carbon buildup.
Theres no way to clean the cylinder walls short of a teardown huh? :(
ricebike
2002 Quest
2005 Altima
seafoam...or mystery oil?
i heard a little water vapor goin into the throttle body while revving up the engine also works, But, may cause more harm than good... water is a great decarbonizer... may clean it all too well to the point where chunks may obstruct some passageways.
well, I heard that from amarok.org list members a while back.
erich
I've heard of using crushed walnut shell blasting as a way to remove carbon buildup. Once the blasting is done just vaccuum out the cylinder.There are also chemical means to remove carbon buildup. Look for decarbonizer.
nismo2887
prigo
^ thanks a TON!
