blaZt. Is it good? + random babaling of an idiot (Yay)
onepuff
check on the skylinesdownunder forums for more info about that. It's not the easiest engine to build.
MaxFNPower
Car: 93 240sx SE Coupe KA24DE (My Dorthy) 97 240sx Coupe KA24DE(Un-Named) 87 Nissan Pick-up (Tin Man)
Onepuff is right they never made a turboed version from factory(I think), and the block is taller you have to cut your hood.
But, still! OOh a 3.0L RB, it makes me tingly.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
MaxFNPower wrote:Onepuff is right they never made a turboed version from factory(I think), and the block is taller you have to cut your hood.
Does anybody know how to read? Sheesh..
The 30DET was never released as a production motor by Nissan or Holden (GM), but is a semi-common engine swap in Australia. RB30 block + 25DE head or 26DET head. If you use the 26 head + ITB's / intake you would need not worry about the blocks deck height / hood interference. (I had to cut my hood skeleton due to the stock 25 cross-tube intake manifold. Converting to GT-R intake / ITB's shortly.)
It is not a swap for the weak of heart, nor the shallow of wallet. Easily expect to invest USD$ 12-15,000.00 for this swap, and that is doing everything yourself (except machining work).
Easier solution: Just buy an imported R32 (or maybe even an R33) GT-R for 12 grand instead and be done with it. Period.
MaxFNPower
^ Sorry I didn't see you post there L0nestar I still want one though but only after i get a machine shop up though and an extra ten grand.
Also I can read! Just cant see...
brizanden
Car: thrased kouki ftw
ill stick with the 25DEt im not tryin to get into rb26 price range
MaxFNPower
I just want 200 whp out of my KA, NA or t-25 (or any other light turbo). There is a project I'd like to do involving rotary valves and a rb30 short block would make a nice start.
But thats a few years away, right now I want blatz but I cant seem to save any money right now with gas so high, I only get 23.5 (after I got an o2 sensor that worked), hell I own 2 240's now maybe I should just get the money out of savings It'll probably pay for its self in diagnostics, and hope fully in improved millage if any more sensors are bad.
MaxFNPower
Oh ya forgot, I went up to dads and got to stay for about 3 hours before I had to drive back down for surprise jury duty.(4 hours in less than 12 hours on 3 hours of sleep.. fun) I was really impressed, the car was a lot faster than Dorthy.86,000 miles and the car seems brand new.
brizanden
^ dam straight s14 ftmfw
MaxFNPower
^ I still think there ugly as sin, but maybe it just because mine is GREEN. Greeeeen though wtf... I saw a red s14 at Carmart the next day after jury duty though and it looked damn good. Maybe its just the GREEN color idk.
MaxFNPower
Post 100 KA= and
brizanden
^ no non o no green = the new hotness. red = the old and busted. also u have a zenki so stock body looks a bit ugly but they can look good. and one more thing i need to correct u on ka= rb=
MaxFNPower
No, sorry in my opinion the KA is still a tank, believe me I've put mine through hell. The RB is just a hell of a lot better engine, more potential and probably tougher. It's probably like this the KA=Sherman the RB=Abrams both tanks just ones a lot better. See?
brizanden
ko ill agree lol
MaxFNPower
I've decided that when I get my tax return I'm buying blazt, finally... Or coil-overs, damn choices damn.
Oh ya and your up late Ya I never sleep too.
brizanden
coilovers ftw
MaxFNPower
you heard of any good brands with coilovers under 1k?
l0nestar
2004 Toyota Altezza
If you are stuck on going with coilovers, go with Megan Racing.
I'm not a fan of coilovers though, at least not for serious driving / HPDE. It all depends on what your goals are. If you are just using it for a Daily Driver, I would avoid coilovers at all cost.
onepuff
I like my stance basics so far.
exode
Car: 90' 240 w/ 400hp SR20DET
MaxFNPower wrote:you heard of any good brands with coilovers under 1k?
the buddy club racing specs. Amazing coilovers, and they are just DAMN good knock-offs of top-end tomei's. Just at about 1000.
Tein also does a low-end coilover, but you'll get more for the money with the buddy clubs.
Plus buddy clubs are stiffer in the rear +1 for real racing.
exode
oh by the way
When people refer to the RB30, the version most common is just an over-bored RB26DETT. 2.6 liter to 3.0 liter, most people when referring to the rb30 are referring to a 3.0 liter RB26. Top Secret's owner has an RB30, that was originally an Rb26...make sense? That how it is in Japan anyways. I'm sure the Aussies have a way of bolting up a rb26 head to an rb30 block.
MaxFNPower
Are you sure this is what I'm talking about...
zerothread?id=272625
Your the first person that's said that. Everything I've read says that its a taller block with a longer stroke and the same bore. I could be wrong though.
Oh and if your wrong, don't feel bad I thought it was an over bored rb26 too.
exode
MaxFNPower wrote:Are you sure this is what I'm talking about...
Meh, I was half-right. It is a popular bore, (not stroke however). But they do bolt up an rb26 head to make the big #s!
Sounds like it has harmonic issues past 7500 rpm so I'd much rather keep the Top Secret built RB26 ($30,000) =O
l0nestar
2004 Toyota Altezza
exode wrote:When people refer to the RB30, the version most common is just an over-bored RB26DETT. 2.6 liter to 3.0 liter, most people when referring to the rb30 are referring to a 3.0 liter RB26.
Lie.Visit the RB sub-forum, mention RB 30 - _everyone_ will assume you are speaking about an RB30e from Holden \ R31. You want to use the 26 head as opposed to the 20. The 25 does not line up properly due to VCT (requires drain mod).
Have you ever even seen an RB30 (26 stroker) kit? One of my friends has one in his R33 GTR. He paid 1,500,000 yen for it, direct from OS-Giken. It is insane. I have his spare 2.6 block that was stroked to 2.8L (Tomei). Debating on building it up or selling it. :-\
MaxFNPower
I've got a hand full O' good news,
1. Today is my birthday, I'm 25. 2. Got my tax return today for my state. 3. Tomorrow I'm ordering Blazt.
brizanden
good news
MaxFNPower
Wow, that was fast, hopefully we can get back on track, or I can just start a new thread to review blazt, (man I love comas), , but I like it,.,.,.
brizanden
dude ive been trollin all night like its my job first night of spring break = i am full of win
MaxFNPower
Its the first night of spring break for you? well have fun and get your PPD count up.
brizanden
lol i couldnt figure out ppd but yeah i prolly will my gf went to spain for three weeks and my friends are pretty much done with their spring breaks so im gonna be bored alot
MaxFNPower
^ Posts Per Day - I looked at your watched topic you had two pages, your going to go blind looking at all of those posts. Rest your eyes on some good wholesome pr0n, no one ever went blind looking at that.... Oh wait, on second thought never mind.
