pMaxFNPower wrote:if i have time i'll check the aac vs. engine temp, also i'll send you some logs when after i get off work.
Also, just for my reference what is tps? I don't have time to look it up.
Very nice:) Your AAC opens up more as you decelerate to a stop while mine closes down to 30 percent. I think an input like speed is not getting to the part of ecu that manages idle.MaxFNPower wrote:logs sent
THe "lean" designation is an error. It says lean when it is rich and vice versa. You are nice and rich at the end of your drive ie .87 volts. You start your drive with 0 volts and the program is mistakenly saying you are rich.The consultz program does the same thing.MaxFNPower wrote:Well I made another log today and noticed at the end of the drive again it was running lean at idle, not sure why? Anyway I have to get up early again so I't will have to wait I Might send you the log tomorrow.
shipping is free and i didnt pay tax in canada. if i recall, he said it was a gift for customs. he had these on ebay and they were going for double.l0nestar wrote:Where are you guys using your consult cables from? Mine took a dump recently.
ECUTalk has them for ~$70 USD, but that does not include shipping.
the chinese serial ones can go as low as $35. they are more professionally made. much fewer options if you need the usb one. there are a couple real losers selling junk ones on ebay. ecutalk ran out last time. If you can get an old cheap laptop then you can use the serial cable. It is pretty hard to find these cables used but it might not hurt to ask in the classified.l0nestar wrote:After looking on Ebay, there is only one from ECUTalk, and there is no BIN option and it's $50. :-\
