blaZt. Is it good? + random babaling of an idiot (Yay)
MaxFNPower
Car: 93 240sx SE Coupe KA24DE (My Dorthy) 97 240sx Coupe KA24DE(Un-Named) 87 Nissan Pick-up (Tin Man)
brizanden wrote: u do everything u can to make her happy.
Are you stalking me? Oh and, Thats what every one else tells me.
Na, you came real close on alot of points... Thanks for your help. I'm a going to get off here and install this ram and go to sleep. Nite.
brizanden
Car: thrased kouki ftw
6stalk stalk stalk stalk hahahahah im crazy... lol some people are better at collecting money then others....
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
brizanden wrote:^ nah i don't have that much. prolly gonna do the rb25 the thought of having a legend skyline motor makes me wet.
My 25 makes me happy.
Slaying Honda's and Mustangs makes me happy.
Slaying SR20's makes me even happier.
If your thinking about it, have 7-8,000 ready to do it right the first time. You will be happy you did.
brizanden
yeah i was planning on about 6.5k i have been sourcing alot and planning it all out.
MaxFNPower
No, no, I didn't die... Kind of wish I had though. Just my, carmobo was DOA and just sent it back, my home Mobo died, don't know why, and oh the rest of my life keeps going to **** for no apparent reason.
Well I finally just stole my moms computer to get online, because I know you guys care and wanted to know I was alive and all.
But hope fully every thing works out and soon... At least the carputer(isn't a hobby suposed to relax you instead of stress you out?)
P.S. OnePuff I'll e-mail you tonight or tomorrow. K?
MaxFNPower
Oh Ya the BlaZt cables came in haven't got to try them yet. I'll get pics up tomorrow.
vancouverbc
Car: 1991 240sx
http://www.sr20forum.com/rom-e...hange/
HOW TO: Build a Consult Beta Tester Box
Schematic and Parts List are attached to this post!
This guide is for the Consult beta test box that some of you guys are (hopefully) soon going to try to build. Builders: please post your comments, questions, and pictures in this thread. When I'm satisfied that these things are actually buildable by people that don't wield a soldering iron on a daily basis and most of the bugs are ironed out these pieces should be available for sale on the forum store front.
The schematic for the board is attached to this thread. It should match the boards you are building on. Also attached is a parts list in excel format with links to http://www.mouser.com where you can purchase all of the components. I will supply the circuit board, the white consult-wanna-be plug, and the pins. Note: the box and LEDs are not needed for this board to work. If you want, you can do something kind of slick and mount the board under the dash and use a panel-mount DB9 connector, as shown in the photo below. The board is pre-drilled for standoffs for this kind of mounting, or using other enclosures. These holes are not used for the box I spec, it has internal rails that hold the board. If you do this one piece of advice: mount the DB9 connector a little farther back on the shifter console, if you mount it as pictured when the seat slides forward if you've got a cable plugged it it will hit the cable and bend the connector. Don't ask how I learned this.
Anywho, on with the box. What your trying to build is shown in the picture below. Note that this one does not have LEDs. I haven't yet built a box and actually mounted the LEDs to it as I always get lazy and just call it finished without the flashing lights. The LEDs I've speced are snap-ins, and should mount just by drilling the proper size hole in the box. If I get a chance to build a box with them I'll document this. Ok, for those of you that don't have a box, what you can't see is that this is an extruded aluminium anadized black box, and its built like a little brick. I really like it, especially considering how cheap it is. I think you could drive an se-r over it and it would survive.
Ok, I've broken the construction down into three different tasks: assembling the circuit board, doing the fabrication necessary on the box, and finally building the consult plug. I think its actually easier to do these out of order and do the second task first, but I've got more photos right now for the board assembly so thats what I'm listing first. For the second task, it helps to be using a board thats not already stuffed just for mocking things up.
Also note, there should be hi-res versions of these pictures in my gallery if you need a better view of something.
TASK 1: Assembling the circuit board
Ok, first off print yourself a good color copy of the schematic. You don't have to know what everything on there is doing, but it helps to follow it along as you build.
Step 1 - Solder in the resistors and the single diode. Resistors can be soldered in any direction, they don't have a front or back. On the circuit board you will see a R# where a resistor needs to be placed. If you fold the leads of the resistor as shown in the picture below it should go in the holes on either side of the marking. The resistors always go in the same direction as the text, and lay directly on top of the text.
Make sure you put the right resistors in the right spots, and put the ends in the right holes. Don't mix up your resistors! Unfortunately I think I'm using slightly different values in the photos than what the parts list calls for, but look at the photos to make sure your putting them in the right spots.
when you get done soldering the components, make sure to cut the dangling leads off with a small pair of cutters. You need to trim them kind of short to fit in the box correctly.
Ok, the diode is directional. You need to place it facing "forward", as the next two photos show. The dark side of the diode is the "front". I actually forgot to place the diode in this step so I'm substituting a later photo, ignore the rest of the components.
Step 2 - Place the ICs and the Transistor
All the little chips are labeled U#, with the label in the top portion of the chip. Each chip has a notch on the center top part, this denotes the top of the chip. Aslo, the writing always goes down direction, and pin 1 is always the top left pin. Note on the circuit board pin 1 is always designated with a square pad. Anywho, place the chips as shown below.
brizanden
^hu h wtf in the wht and where?
MaxFNPower
^ It's some kind of test box for the consult system it's linked to a diffrent forum, I didn't have any more time to look into it though.
brizanden
lol i dont have time hahaha. ill check it out later and let u know wtf it is
brizanden
double post ftw. hey max if u get on maybe you can help me bang this assignment out real quick lol.
problem: Construct a structured, modularized C++ program with a separate function to separately do each of the following:
Display the assignment number, your name, your student identification number Input and display the day, month, and year. The day, month and year should be input in the main part of the program and passed to the function through a parameter list. Add the values of the day, month, and year together and display the results. The calculations are to be done in a function. The results are to be displayed in the function. The values are to be passed into the function through a parameter list. constraints: The program must be modularized by the use of functions. Functions may not be nested. Each function is to be separately invoked from the main part of the program. Program capitalization will be as described below.
MaxFNPower
**** **** dude! I've only written a hello world in C once and it didn't even work right. lol
But, that doesn't mean I cant try. (You've already got it done haven't you.)
Anyway I have vast experience with the halved assed Dark basic, and always used a modular design so I can explain how I did it.
I started with two files, the first being the core of the application which would call functions from other files primarily, it would also hold most of the variables for testing (no help to you), the second is all of my functions done in a separate file based on category. (Guns, movement, terrain, camera.. Yes all I made was games, what you got a problem.)
From reading your assignment I'm not sure exactly what your teacher wants. Not embedded? WTF to me a function not embedded is in another program. Because once you "type Function()" (or what ever it is in C++,) its now a function to be called and is not going to be used until called.
I guess he's just wanting every thing in an actual function is all.
Sorry I couldn't be more help, but I'm alittle drunk and very tired. ( see I even slured my text.)
Hey when you get it done post up your code I want to see it K.
Modified by MaxFNPower at 1:36 AM 4/19/2008
vancouverbc
Car: 1991 240sx
zerothread?id=198192
srtalk seems to have their own software and instructions on making cable
the above link provides list of some of the software alternatives.
obdscantech seems to be free again. maybe warez has something. my computer died so have lost all links.
vancouverbc
Car: 1991 240sx
http://www.obdwholesale.com/di....html
these guys have cable for $60 plus $1.6 for shipping. SERIAL PORT ONLY
http://people.aapt.net.au/~mearcat/Consult/
build your own for about the same price
Modified by vancouverbc at 6:17 PM 4/15/2008
vancouverbc
Car: 1991 240sx
http://www.sr20forum.com/rom-e....html
usb to serial adapter
Modified by vancouverbc at 12:17 AM 4/16/2008
MaxFNPower
Thanks VancouverbcAt least someone is keeping this thread on track, too bad it's not me.
Anyway, I bought the USB cable from blazt, just haven't had the time to try it out though. From what I've read the serial cable is the way to go and I'm kicking my self for not getting it. I just hope I don't have any problems.
onepuff
USB cable has been working great for me, don't worry about it. Data keeps up fine with the engine. I'll try to get that PSU out to you tomorrow.
vancouverbc
Car: 1991 240sx
if you have a serial port, the serial cable would be cheaper but not sure how many people have serial ports anymore. usb to serial adapters are a bit fickle, also.
brizanden
dude no i didnt do it lol. i was seening if u could bang it out real quick seeing as ur supposed to have a degree in my major already. god max u let me down lol. it was due yesterday and i didnt want to do it. hahahahps how do u not know how to writ in c++ wtf did u learn?
MaxFNPower
OnePuff,Thanks, From what I read right after I bought the cable I read some where that the USB has problems running for a long time. Some thing to do with changing ports on you. Oh and look forward to getting the PSU.
VancouverBC,Actually the carputer mobo does have a serial, which would have saved me a USB port, but oh well. Oh and thanks for the info. Just wondering do you know if they have a Linux consult version?
Brizanden,
One, Never could find a good, free compiler. Two, my major was in networking, sadly, dealing mostly with Cisco Systems. Sadly we didn't have a C++ class(Grrrr), we had a "game programing class"=Gay ****, we used Dark Basic. Nice language quick to build things but not very powerfully. I've only had a taste of C++ and I want more thats why I'm getting this some time soon I hope. http://www.flutterbot.com/
Nite Guys, MFNP
onepuff
Yea it does change ports on me every once in a while. It happens very randomly, not every time i start it up. Kind of annoying but oh well. It's very easy to change ports within Nissan Datascan, so it takes about ten seconds to fix. I thought it was because i was running it through a usb hub. Doesn't help that i'm running it through Parallels on my Mac Mini. No serial port for me.
brizanden
MaxFNPower wrote:
Brizanden,
Nite Guys, MFNP
dude microsoft visual studio is alright and u can practically steal gnu online at some places.here is a ****ty sample of some of my old pointless in class modular code. (its gonna be a long post kids) edit: instead of running this thread ill make a test thread and just link ithere ya go max zer...d=208
l0nestar
2004 Toyota Altezza
MaxFNPower wrote:OnePuff,Just wondering do you know if they have a Linux consult version?
Dunno. But you could always try running the various Consult software via Wine. I'm interested to see your results if you do.
vancouverbc
Car: 1991 240sx
search for linux at srtalk. they have talked about linux
MaxFNPower
Brizanden,Hmmm, just as i thought it seems almost all programing languages have the same flow, it's just the commands that are different. Well there really similar actually. Doesn't visual studio actually cost about $150?
l0nestar,Oh, ya I'm going to have to try that.
VancoverBC,I'll have to try that. I just got my computer fixed, got to move from this side of the room to the other so I can use my LCD, so probably tomorrow I might have time to check that. I have to fill out an application to a Honda dealership(Motor sports of course), so I might be busy tomorrow. They seem to really want me.
All,One step closer to actually having a computer in the car i just bought a 750 Watt DC-AC converter so I can run the CRT, plus the computer i'm going to test Blazt with. All i need to do is re-install 2003 and I'll have a 10GB HD to sacrifice to the carputer gods.
Sadly it turns out that the AM2+ will not actually work on the AM2 mobos so I just pissed away $170, that is if newegg dosn't take it back, they won't probably.
Well I'll talk to you guys tomorrow, right now I'm going to eat then move every thing and work on that application.
Nite, MFNP
brizanden
no search the google jusrt say ur a student when it asks its free to reg c++ microsoft visual
MaxFNPower
Check this code out
Just a little DB game I was working on never even came close to finishing it, but you can kind of see the structure and commands.
zer...30618
P.S. hey OnePuff where's a good place to run battery cables through my fire wall I haven't really looked yet so just wondering.
MaxFNPower
Never mind OnePuff, I actually looked under the hood last night. i don't have air so I've got plenty of good holes to use.
P.S. For those of you that have Finals Good Luck.
brizanden
not i sir i got like 7 weeks left of this bs
MaxFNPower
Brizanden,That sucks, but look at it this way. I have until next Tuesday to get my final done, and it's huge. Oh well, I'll be glad when it's over myself, good luck on the rest of the year.
OnePuff,PSU received, thanks.
l0neStar,Just wondering what live booting Linux you recommend, I haven't looked into it in over 4 yr. If you've got one you use with WINE on it and you like it tell me k.
All,Well, got WIN 2003 Install to take on my PC don't know what the problem was before, but it's working now just need drivers and I'll be good.
MFNP
