Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Tue Apr 19, 2005 3:15 pm
a wider wheel on the same tire size decreases your effective aspect ratio, increasing turn in and stiffness, but decreasing load carrying ability and contact patch to an extent.
Jspec, check your tire pressures F/R, and keep in mind you have a setup that will force a bit of understeer (esspecially if the rear offset is lower than the front)...so it may be overloading the fronts.
Have you marked the tires sidewalls to see if the tire is rolling over and its not a setup problem? THe ES100 has a very respectibly stiff sidewall, and People are usually quite impressed with their turn-in (just not their treadwear and higher heat tollerance)...
-Chet
