No, you misunderstood. While I thought the screen went out on the AC/ Heat controls, it turns out the heat was probably just off when I thought it was on. I am familiar with the footwell problem, though. Thanks.driverdriver wrote:In the '93 and '94 model J30's there was an issue with intermittantly blowing heat in the footwells when the heater was off. Up here it was a recall issue with a free fix. I don't know about the States. I would check with your local Infiniti dealer.
All you have to do is turn the temperature down.... It will stop blowing hot.driverdriver wrote:In the '93 and '94 model J30's there was an issue with intermittantly blowing heat in the footwells when the heater was off. Up here it was a recall issue with a free fix. I don't know about the States. I would check with your local Infiniti dealer.
Thats what it defaults to when you turn the climate controller off, to maintain airflow...driverdriver wrote:In the '93 and '94 model J30's there was an issue with intermittantly blowing heat in the footwells when the heater was off. Up here it was a recall issue with a free fix. I don't know about the States. I would check with your local Infiniti dealer.
