DashingMax wrote:Whoa!! That screen and everything being controlled via that screen that only Infiniti can fix.
This is EXACTLY why I bought the Elite Extended Warranty.
Please let us know the diagnosis. Hopefully it is just a battery.
Way to go there on that "Elite" warranty. Hope they used lube
And it doesn't sound like the screen but more of a communication problem between it and the other systems it's connected to. Has your car been in an accident? You could need a new Nav unit or the screen comes out as a unit and is replaced. Good thing you are covered under warranty, but it is relatively easy to change out. If you can use a socket to remove a bolt, then you can remove that by yourself if needed.
We have the FSM on this board and we can help you use it. That's why we are here.
Good luck getting it figured out.
