s13-t »
https://forums.nicoclub.com/s13-t-u99439.html
Wed Jun 17, 2009 8:43 am
thats a good price for a swap. but keep in mind that to do the swap correctly you need to spend some extra cash replacing a few things. Like the oil pump, water pump, thermostat, and I would replace all the exhaust gaskets. The more things you replace now, the less things you will have to replace in the next few months. I swapped mine in without replacing anything and sure enough, bad oil pressure, bad gaskets, and a bad pcv system all within 4 weeks. thats my .02
but definitely see about a compression test. If you cant do it, ask him to do it taking pictures of the readings from each cylinder.
