blacktop sr20det running lean help!
1990nismo!
Car: 1990 Nissan 240sx
ok took my car to the dyno and im running very lean........ i was told to install a fuel regulator...... im at 65 psi and im know it supposed to be at 43psi...... plzzzz someone tell me how to do this and where it should go...... and no im not the greatest tech but this shouldnt be hard right???
duffman1278
Car: 89 240sx Hatch, the wildcats!
65 psi?!!? wtf? You know, writing your setup would help. If it's all stock then you should be fine with a stock FPR. Somethings off there, also there's an SR20 forum.
1990nismo!
not exactly 65 maybe 62 or 63 allz i know is im not at 43...... um stock sr20det blacktop stock turbo..... headers and aftermarket intercooler...... dats it basically...... i have the regulator i just need to know where to put it and how thanks
duffman1278
You should have done your HW before going and putting parts like a FPR. Now go read up on how to adjust, it unless someone else post up on here is nice enough to give you the answer. Sure I could tell you, but then you wouldn't learn your lesson.
spooled240
Car: kouki s14
if you are at 63 psi instead of 43 then you would run rich, not lean.
get your FPR in and turn that bolt on the top to adjust the fuel pressure
