Blacktop sr20 vs silvertop!!??? Help!
Tkdteen05
Car: 1996 240sx sr20
Hello! So my question is very simple. I am a total noob to 240's and swaps so I figured I would come here for help. Which engine is best/better to put in a 240? A SR20 or an RB20!? Please help!
Modified by Tkdteen05 at 9:51 PM 2/23/2010
sm0611
Well if you are talking about sr20det's then maybe a blacktop compared to a redtop would be better. Check out through some of the post. You will learn a lot. Good luck
J14cm7
Car: 95 240sx S14 SR20det
Tkdteen05 wrote:Hello! So my question is very simple. I am a total noob to 240's and swaps so I figured I would come here for help. Which engine is best/better to put in a 240? A SR20 or an RB20!? Please help!
Search search search. This is the most basic 240 question and the answer is everywhere. Your post and your question are two seperate things. An rb20 is NOT a swappable without modification. An SR20 is a direct swap.
Please search in the future
Seanzyyy
Car: 1990 240sx se coupe
although it's not as messy as an rb25/26...Will bolt in using stock mounts and R32 crossmember. you can also use aftermarket ones from companies such as McKinney and TopHat Will use stock 5 speed driveshaftCustom downpipe may be needed for both S13 and S14Electric fans are requiredCustom throttle cable bracket may be requiredTach adapter or gauge cluster swap required for accurate tach signal^from sticky in the rb section
overall though, you'll spend about the same i think.they both have great potential sooi guess it's up to you if you wanna say "i have an sr" or "my car has the heart of a skyrine"
