Blacktop S13 SR sputtering hard under WOT
RickyBobbyS13
Car: 1990 240Sx- S13
So I’ve got an S13 blacktop in my car and under full throttle it’s running like it has a boost leak. Sputtering and stops building boost. I’ve leak checked the whole car for any possible boost leaks and fixed any I found. Car starts, idles drives down the road fine just cruising but once I try to get into it it builds a little of boost and the sputters and stumbles all over the place. I’ve done plugs(gapped to .28) and coil packs as well as 255 fuel pump and new filter. Car runs a solid 10.0 on the wideband so it doesn’t seem to be any fuel issues.
Thanks for any help.
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I would check your couplers for any tears and your IC coupler clamps to make sure you aren't getting any boost leaks under pressure (but sealed under normal op). I had a similar issue and it was a torn coupler.
