Blacktop or Redtop SR20DET?
fastball48
Car: currently 1997 accord coupe, soon to be 1993 240SX
I'm about to purchase a SR20 motor and was wondering what some of you guys would recommend between the blacktop and redtop? and why... also, how many pounds of boost does a stock SR20 run? Any info would be awesome. Thanks
ILikeMy240sx
Car: SR Power
please check the sticky (FAQ) before posting stuff like that.
I like seeing technical questions on RWD-SR forum... I dont want this forum to turn into anoter 240/silvia forum.
otterman
Black top if you can afford it, less miles better chance of it being in good shape.
Stock boost is 8psi.
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
otterman wrote:Black top if you can afford it, less miles better chance of it being in good shape.
WRONG! Stock boost is 7 psi on an s13 black and redtop. 8 psi on an s14 notchtop(not blacktop they are all black). Read the stickys and SEARCH
otterman
I ask good questions wrote:WRONG! Stock boost is 7 psi on an s13 black and redtop. 8 psi on an s14 notchtop(not blacktop they are all black). Read the stickys and SEARCH
Damn it, you're right. I was off by 1 psi
lol not much harm done. just trying to act like i know it all i guess.
otterman
lol that guy probably would have bought a blacktop/redtop thinking he'd get 8psi then get all pissed off cause he was only getting 7 if you hadn't corrected me!
otterman
Thread Jack FTW!!!
Reading your sig, I ask good questions, you need to post here. zerothread/192297
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Get a blacktop if you can afford it (newer motor = less miles and abuse, hopefully. Also has newer head casting and a nicer oil pickup design)
If not, buy a redtop and put in a blacktop oil pickup. The casting differences between the black and redtops are not drastic enough to cause power differences.
