inertiadrft wrote:
im talking about the difference on the s13 red & s14 black top, now if you guys are talking about the s13 red & s13 black????WHAT'S THE F****N DIFERENCE!!!!!!!?? its the same sh*t!!!
wrong...the heads are ported just a little different. they are interchangable, but the amount of work and all you have to do to realize the difference makes it not worth it. You really would see the difference on two identically modified SRs and a dyno. you would see the turbo would spool a hair faster and the more you modify the two different heads the more you will notice the differences in air flow. that is why they cast the lines in the head, because they were designed a little differently, check two stock dyno sheets with identical mods and tuning. blacktop heads always have a hair sharper curve and if when both cars are in the 350 + range you will notice that the blacktop will put out a little more torque and the curve is a hair different. again the gains aint worth the work
If you are talking about the redtop with the lines cast in the front then that head is going to be exactly the same as the blacktop. they made a later redtop that shared this head with the blacktop, but most of the redtops that you will see with blacktop like heads were swapped in japan or they are blacktops that were painted red. You can use either one.
