KimberKenobi »
https://forums.nicoclub.com/kimberkenobi-u60342.html
Mon May 14, 2007 3:03 pm
For those of you who aren't on CarDomain, I'll make this a simple cut and paste...
CodeRed and Clipsed can see fit to augment...
Posted by CodeRedVersa04/04/2007, 07:17amwell, first i got a very fine sand paper and went over the whole grille. i then washed it with a little dawn and water making sure no residue was left let it dry. wiped it down with my microfiber towel then i primed it with a sandable primer (3 coats allowing 30 min bewteen each coat). i then let that dry for an hour. next i put krylon plasitc paint on it three coats again allowing about 30 min between each coat. next i put a clear coat on to give it that gloss again three coats allowing 1 hour in between each coat. and thats it let it cure for 24 hours and pop it back in.
Additional: and Shreqboi too, didn't realize I was leaving someone out ;oD
Modified by KimberKenobi at 10:27 AM 5/20/2007
