blacked out B pillars
Home of the Nissan Cube forum and CubeDriver.com
randode
i wrapped the B pillars in flat black vinyl to match the vinyl on the back doors.i made patterns if anyone is interested.
chompsticks
Car: ???? Nissan Cube Krom
Can you make them in gloss ? Do you think you could make a piece for the driver side to cover up the plastic piece and make it look gloss instead of plastic? I would def be up for that!
chompsticks
Also, those rear spacer shims.... Are they located between the hub and the rim?
randode
chompsticks wrote:Also, those rear spacer shims.... Are they located between the hub and the rim?
the spacer shims go between the axle and the hub bearing.
i can do gloss black on the vinyl.
chompsticks
How hard is it to install the shim? I am def interested in the gloss vinyls for the B pillars. Any chance on having one for the rear halfcircle piece? Also how much would they be?
TBrack
Car: none
mine were blacked out from the factory
randode
TBrack wrote:mine were blacked out from the factory
pics or gtfo
chompsticks
LOL, At first I was like huh? But now I got it. nice one!
TBrack
Car: none
lol had you goin for a min there
BrassMomkey
So how much are you charging. I think it looks good blacked out like that!
randode
BrassMomkey wrote:So how much are you charging. I think it looks good blacked out like that!
they are on ebay: http://cgi.ebay.com/ebaymotors...ef18f
Return to “Cube Forum”
