redsx13 »
https://forums.nicoclub.com/redsx13-u72643.html
Fri Nov 21, 2008 9:13 pm
Recheck your tps! at acc, it should be around .5 volts closed and 4.5 volts open. now, turn your car off,and unplug your tps. check the ohms between pin #1 and #2. you should get around 2 ohms when closed and around 10 open. the numbers dont have to be exact, but if the tps is bad, the numbers will be way off. My car had a similar problem, and i had to replace the tps.
