Black smoke??
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
Whats this mean? Every once in a while i get a puff of black smoke out my muffler. I dont know what black smoke is and the back of my car has black sut on it too. Help
And its not oil it just black Ka with 128k and mobil 1 1040
AzurE
rich fuel mixture.....could be air filter , o2 sensor, fuel press regulator, weak ignition.
NateDogg
Under what circumstances?? On startup? Accelerating? Certain rpm? Load?
NISTECH
check your coolant temp sensor connection. near the front of your intake manifold ,2 wire connector. if its green and crusty inside clean the terminals up and recheck it.
Charlie240sxt
When i see it is when it sits at a stop light and i rev it up to about 2500-3500 really quick. That and my engine light is on guess ill see what code its trowing maybe this is the problem???
xdreamz
Car: chevy and nissan,,, doing it better, building it,, makin it look right good and smooth
hey charlie, in my 89, it used to do that, no matter what i did it kept comin back, but when i swapped all exuast (cat+catback) it didnt come back, ofcoarse i only had it another 6mo's but hey, worked for me. never knowjust throwin ideas around also valve seals,
Evilnightmarez
lol could be just bad rings, i have a 94 240 sx and the same problem and it goes through some oil. I bought it from a crock mechanic who says he just did "a complete head and valve job" well nothing is new on the engine, not even the battery and i told him im not a moron which is why i got a 95k mint condition body and probably 75% engine convertable for 1500$. But anyhow, if you step on it and it ****s out black smoke its either running to rich or ur shooting oil past ur rings and some is unburnt?
DriftBandit
Car: this is my 3rd 240sx
I have a 95 240 with a s14 sr and I am running really rich. does anybody know how it can be fixed??
1TuffRS
black smoke = running richblue smoke = burning oilwhite smoke = burning coolant
Normally if you are running abnormally rich I would check the things that Azure mentioned. If all those things check out and are fine, then depending on your mods what you really may need is just some tuning. Get some gauges so you can see what is going on and then go from there.
DriftBandit
I have an upgraded fuel pump, the warblo 255lph, do you think this could be the problem? Does the ECU need to be reprogramed or should the fuel pressure reg take care of that?
AzurE
get a "GAUGE" and check the fuel pressure. should be about 35 psi at idle, then disconnect the vacuum hose from the regulator and it should be about 43 psi.
255lph may be a tad more than the regulator can deal with..
67 gallons per hour would feed a 496 kieth black hemi
DriftBandit
Ok thanks, I was thinking about getting an adjustable nismo FPR anyways, hopefully it will help.
