Black smoke
implict
well well well well..... got some signs telln me im spitting out some black smoke..... bumper is gettn a lil cloudy and friend told me some was comming out when i got on it..
This either means.... im runnin a lil rich... or.. ???
need some help from the nissan gods.
Also tends to smell like fuel!!!!!!!!!!!!:help
jacob360
Car: 2 S13 Coupes
Rich
implict
im also running straight 3' piping
Nismo_Freak
Car: 89 Nissan 240SX
Black or Brown Smoke is fuel...
If your turbo you are running uber rich, correct it If your N/a then you have a fuel pressure or timing problem
implict
how do i correct it
XCrunner19420
Fuel computer, Apexi SAFC.
implict
well, isnt running kinda rich good.... i mean... im not detonating.. ( which would be bad )
red240ne
Car: mmm...donuts
upset stomach
nolaws4evr
Car: cruisin tha streets of Huntsville, runnin down hondas, tryin to get money out of my insurance comp.
implicit, what engine setup are you running with that 3" exhaust?? also what muffler did you go with? I am planning on goin with a similar setup.
Josh
slw240sx
Car: 1990 Ca18det 240sx Hatch
some what rich isnt to harmful, bad on mileage and performance.
too rich you can detonate.
you can also at lower RPMs cause what they call bore wash. thats where unburnt fuel builds up on the cylinder walls and is washed onto the pistons and rods durning the cumbustion cycle, and we all know what gas does to greasy oily things right? bad bad things happen if you have borewash,.
my advice check all your boost pipes and vacum hoses. then check or change your O2 sensor, some black smoke on a turbo car is normal.
i just two days ago was blowing tremendous amounts of smoke and the car ran like poo, i was hitting boost cut at 7psi. but my vacumn was normal, turned out to be a ripped silicone connector on the hot side goin onto my intercooler. fixed it and the car runs good once again, i still blow black smoke but i also have other problemns i have yet to track down. . check your oil for the smell of gas, if its super strong fix the problemn and then change that oil. . ..
Jon
implict
well its not poring out black smoke... its just when REALLY get on it. pops a bit too.
gettn my fmic installed this weekend... and still im kinda sketchy on atmosphering my bov... ive got the hks ssqv... ( i still dont quite understand what it means. )
slw240sx
what dont you understand? if your on AIM hit me up at slw240sx ill answer any questions you have the best i can!
implict
k i will thanks
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
Balck smoke could be 02 sensor or time to replace that inexpensive charcoal cannister filter element. The fillter element usually doesn't get touched until it goes. Just a thought
slw240sx
im guessing he doesnt have a charcol canister anymore like most of us dont.
Bubba1
2024 Honda HR-V
I can't speak for most, but since PA emissions laws are tough, I had kept it in mine. Who knows, implicit might very well still have his. When my S-13 had the started running rich around 150K miles, that $2 element was the fix. I was thrilled the fix was so cheap. Actually the car ran pretty strong rich, but didn't idle as well. It didn't stay rich for long.
Good luck
