black smoke
L337 H4x012s
Hello, I searched but couldn't find an exact answer to my question. I was wondering why sometimes after i start my car and begin to drive away, for the first 10-15 feet a trace of black smoke blows out of the exhaust, not heavy but noticable then no more black smoke.
Any clues>?
sammy
Car: cars, guns, music......the usual guy stuff
only when you first start it up? might be worn valve guides
p00t
black smoke = engine running rich
if it does it only when u first start up it probably means there was extra gas in a cylinder (leaky injector?), or its just rich on start up for some funky reason... if you dont have any other problems i wouldnt worry about it.
float_6969
Black smoke is extra fuel that isn't being burnt. If it is only coming out when you first start the car, I would say that it is either a leaky injector or your temperature sensor is going out and feeding an incorrect (falsely cold) signal to the ECU. Do you let the car warm up for a couple of minutes before you take off, or do you just go? Try letting it warm up first and see if it does it. Keep us updated!
L337 H4x012s
k thanks, yea i really don't warm it up much, but my injector needs replacing when it goes out completely
float_6969
Hey sammy, if it was blue smoke when it first starts, it would be the valve guides. Chevy's are infamous for that. Smoke when you first start them and then quit. I've never heard of Nissans having problems with valveguides so that would be an odd occurance.
