HwnStylin »
https://forums.nicoclub.com/hwnstylin-u10810.html
Thu Apr 08, 2004 10:43 pm
are you running a test pipe ??? if you are, there is going to be black smoke when you boost. obviously the catlyctic converter cleans up the exhaust and if you dont have one ....its going to be black smoke. even with a high flow cat there is still some black smoke that comes out. its typical for engines to idle high when you just start it up, and then idle lower when it gets warmed up. my SR does the same thing. except mine starts up on one try. it idles at about 1500 rpms for a couple minutes but once it warms up, it idles around 850 to 900 rpms. dont worry, its typical. the deal with the exhaust manifold gasket, if you can hear exhaust leaking out of where the manifold contacts the gasket and block, then you will lose some power. if you are certain that it is your exhaust manifold gasket that is broken, i would suggest replacing it. hope this helps. good luck.
