- black smoke- idle weird
POOPmouth
Car: The Devils pimp ride
ok - i checked my spark plugs and they were all dirty -- changed them and got alittle better- got a code 54 ingnition -
let car run alittle and notice when i rev the car my oil light comes on - and wont let me rev past - a serten poin - checked maf - still good changed with newer on and problem went away as for bunring black smoke - its still pouring out-
i think i could be a coil pack - or even a stuck injector - pissed off can drivelost job lol - sucks - so need to get it up or find new job and rebuild it -
- any info would help
POOPmouth
bump
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
The oil light concerns me. It is triggered only by a pressure sensor and if inadequate pressure is present, the light comes on. Like when you first start it up it takes a second for oil pressure to come up. I would be more worried about that than anything with black smoke. Could be that your oil pump is failing or the oil pump drive is rounded off. What motor do you have specifically?
I don't really know what could be causing black smoke. It's either a lot of fuel or oil. Did it make any noise or anything obviously bad like that?
POOPmouth
ok - rb20det is what i have--- no weird noise ---kinda rev bounce due to vacuum leak-- oil like - came on when i changed my oil -- might be oil pump-- car was driving fine - vacuum leak got bad and it started to die - - then wouldnt start- -- nobody has rb20det intake gaskets without buying hole kit - and smoke is kinda black grey -- says grey could be coolient- or blown headgasket?
