jltibbs »
https://forums.nicoclub.com/jltibbs-u32412.html
Sun Aug 12, 2007 2:45 pm
welcome aboard.
if the engine is vibrating, you may need to check out your motor mounts. "rpm playing all the time" do you mean fluctuating?(sp?) if sdo, you may have a vaccum leak or may need to adjust the idle air control valve located at the rear of the intake manifold. (should just take a phillips head screwdriver) try those and let us know what you find.
