18x8 4x100/114.3 45 Offset
found them on craigs.
i am looking at the tenzo tenspec
and what size tires would i need?
sorry!! i known this is in the wrong part of the forums, but i am looking for a speedy reply!. thanks!!!
for sure brotrigger_storey wrote:It always depends on how good the deal is. Sometimes its cheaper to buys wheels seperate than tires if you have a good place around that will mount and balance for a good price. Alot of guys just go with the tire and wheel combo because the dont want to mess with having to get them mounted and balanced. The thing to watch out for is if the place your buying from mounts and balances them with the tpms sensors also or your just going to have to turn around and pull the tires back off anyways. If you need any info just pm me and Ill give you my phone number and explain everything a little more in depth. Good luck bro
trigger_storey wrote:If you buy tires and wheels seperate just make sure you either buy new tpms sensors off ebay or through your nissan dealer or you can take the stock ones out of your stock wheels and tires and have them put it the new wheels and tires. When you take your car in just tell them you want your sensors switched over to the new wheels and then the new tires mounted and balanced. If you buy the wheel and tire package you need to see if the place your buying them from offers new tpms installed or once you get them you will have to have the shop take the new tires off, put the sensors in, and then remount the tires all over again. Also make sure whatever wheel you buy you see what the hub bore is on it because alot of companies run a different hub size than what our coupes are. You can just google hubcentric rings and see what Im talking about. Once you pick the wheels find the size and then get the reducer to your hub size which is 66.1 I would suggest the aluminum ones as the rubber or plastic ones can crack or get hot and melt. If your family owns a tire shop you should have no problem getting this done. Anything else just ask. I just had all this done and I think it cost me about 80 dollars to get everything switched over and new tires mounted and balanced etc. And that was just from some shop down the road, no deals or family etc.
for sure bro! ty!trigger_storey wrote:Its just alot of the wheels they make dont fit on our car. The inside of the rim is bigger than the actual hub on our car. The ring is basically just a spacer that fits over the hub to make the rim fit onto the car. Helps make it fit tight and gets get of vibration etc. Anything else just ask man. I had alot of questions before I started doing things to my car also. I came from a mustang and never knew anything about hubcentric rings or tpms sensors etc.
