No, you should still do a base compression. It is also possible the octane booster you are using is causing this.rightfoot wrote:One reason I've never bothered is that when it decides to run well, it runs very well, and very strong. If I was having compression problems, that would not happen right.marty1mc wrote:Have you tested the compression? I would start there and make sure you aren't having ring or valve issues that are causing it. Put fresh fuel in it after draining what is in there and don't add octane booster to it. Put in new plugs, clean all your connectors for CAS, PTU, coil packs, injectors, TPS.
When you pulled the plugs, did you feel the black soot on the plugs? If it smears, it's oil. If it's gritty, its gas residue.
