Update DIY Radio Bezel Vinyl Wrap (Black Carbon Fiber)
andre1038
Car: 1994 Infiniti J30t (Sold)
1990 Nissan 300zx (RB Project)
1994 300zx Twin turbo (500hp Daily)
2012 M56s
1998 Infiniti Q45 black on black (Sold)
1996 Infiniti G20
1992 Infiniti Q45 (R.I.P)
trying to see if anybody wants this radio bezel for free (you pay shipping of course lol) if not i will keep it as a memory
Reason I'm giving it away is because its a radio bezel i practiced on, it was my first time vinyl wrapping any interior trim piece. I stripped the bezel down to pure plastic (Yes the Z bezel does come apart just be sure not to lose anything lol)
I have a big box of Meguiars Wraptivo Carbon Fiber Black so i gave it a shot with a spare radio bezel i had here from my project. Didn't come out half bad for my first time (i will get better :biggrin: )
O and the catch is this bezel is only for RHD Z32 (i took this spare bezel out from my jdm front clip and experimented on it before putting the wraptivo on the bezel thats on my car)
Here's a video how to install it if any of you guys want to try it out and buy the wraptivo but will warn you it is expensive i luckily got the box that cost 160 retail (this box has enough to cover a hood/roof) for 40 bucks locally but that was pure luck.
http://www.youtube.com/watch?v=eWZdL1GOfcQ
Here's a pic of the part
what you guys think for my first time? (i made some few errors but not noticeable)
ADDED EDIT (1/11/13) D.I.Y Begins here
Material Needed
-Vinyl to cover the part you are wrapping
-Good sharp blade (new would be best)
-Screwdriver (phillip's head)
-Heat gun or Hair dryer (With the heat gun its faster due to it getting up to temperature quicker, i have used both and results are very similar. Used Hair dryer for this D.I.Y since i know its something everybody will have)
-Fingers or the squeegee some vinyl kits come with to sort out the wrinkles if any (the material i have doesn't form air bubbles since its air tight vinyl material but it can form wrinkles here and there when installing, if it does use a little heat and smooth out or pull the vinyl off and reapply so wrinkles are gone)
-Rubbing Alcohol with a clean rag to clean the part good or in this case i used baby wipes which really worked well only thing is afterward i had to pass a dry clean rag to completely dry the part.
-Something you can lay your vinyl and bezel so when doing this the vinyl wont get scratched (in my case vanilla folder)
Note: in order to do this really good you will need to Disassemble your radio bezel, i tried cheating when i did my very first one but by not disassembling it the results didn't come out good.
Disclaimer: I am not responsible if you mess up your Vinly (by overheating it) or breaking your bezel (when you disassemble it). Most likely you wont break your bezel if you gently disassemble it with a little persuasion but there are those out there who don't know their own strength so my advice is be careful and it will not break trust me.
First step ( Disassemble the radio bezel)
To Remove the Bose cover there is only 4 screws holding it down remove them, also remove you clock by undoing the 2 screws holding it.
Next would be the entire air duct/ Air vents portion has to be taken out. (A total four screw holding it) This is where you have to be gentle yet kinda persuade the metal bracket portions holding it down (where the bottom 2 screw that hold the air duct go). Once you have unscrewed the 4 screws lift up slightly on one of the metal portions and gently sneak out one portion of the air duct then lift up the other sides metal tab to slide out the whole assembly
(i will add pictures of the disassembling tomorrow since its getting late where im at only uploading important pictures today)
Second Step (Clean the bezel or any other part your gonna wrap)
Wipe it down good cause remember the vinyl has to stick real well to the surface for it to look good. (my bezel was dirty lol)
Third Step (Measure the amount of vinyl you want to use, try to maximize your material because it's expensive)
P.S my girlfriend gave me the Z jacket as an early present for my bday (January 14th :mike )
Remember give yourself a little extra
YUP :yesnod
Fourth step (Time to start wrapping)
Peel of the vinyl off the sheet you got measured and gently lay it across the part while using either your fingers or the
squeegee that was provided (if you got one) to sort out any wrinkles. If the wrinkles are too much pull of the vinyl gently and do it until you think it looks good. (Note if the wrinkles are very tiny using the squeegee and heat and it will smooth out)
Lay it gently
start pressing it around the corners with your fingers or squeegee
sorting out the wrinkles
This is what it should look like (smooth around the edges no winkles (winkles in the areas your gonna cut out is ok)
Next use heat moderately so you can make the Vinyl soft enought where it becomes easy to mold around corners and press down on places where the bezel dips. You will see the vinyl start to take shape of the actually part itself. Once you got it heated and formed you should be able to see where you have to cut.
Heat makes it soft and form to the actual shape (best time to sort out wrinkles and the best time to see where your gonna do your cut outs)
Squeegee
Heat corners very well so it can mold to the round edge (warning this may burn you a tiny bit since you vinyl wrapping under heat see my finger and how close it is to the dryer) When it comes to the corners pull very slightly and then tuck towards the back side of the bezel
Fifth Step [most time consuming step there is] (Cutting the material, when cutting don't cut too close to the edge of where your wrapping it because you will need to tuck it inwards toward the radio, vent, clock and vent direction slots. Also when you cutting your slots its easier to heat the material a little so the material gets a little soft making the blade cutting through it like nothing)
cut your outline Remember give yourself extra material so you can tuck it inward
You see how i tucked the big portion inward and the small extra portion the top inwards as well
This is where the bose cover goes, i tucked it in until it hit that metal bracket. I cut where the vinyl was starting to go upwards. once its cut cleanly heat and press so the piece being tucked in stays. This process is the same for the both rows
Both rows tucked and wrapped and ready :)
When it comes to the clock slot area and the other slot areas where the scrolls for the air vents go its a little tricky and this is where i messed up the first time i developed a trick which will work but you have to be patient for it to look good
(I will post pics of this tomorrow due to being late right now here in Florida)
Heated so the vinyl can form wrap that part that dips
Pressing while soft especially where the slots are
Shapping it out (remember give yourself extra to tuck inwards don't cut all the way to the edge of the outline)
Getting there lol
Those air duct slots are a bit of a pain but doable (be patient with those)
Okay see how i tucked the vinyl in that slot i basically did a slit in the middle of slot when the vinyl was still covering it completely then while heating it pressing it in the slot with my finger or you can use a tiny flat screwdriver to press it down (just do not scratch the vinyl)
Sixth Step (Heat the whole vinyl so it can seat on the part for good, if some vinyl starts flaring up which is normal since the heat makes the vinyl soft and rise just press it back down and hold it down until it stays stuck which it will once the vinyl cools down)
Seventh Step (Reassemble your Radio Bezel and it will look good if done right and also don't forget to wrap the center piece cover (which covers your screws from being exposed) of the bezel :biggrin: )
I post this link again because if someone needs anymore live view of wrapping this video from the same company i bought my wrap from is very informative
Time estimate (2 to 3 hours depending how perfect you want it) (took me 2 to get it perfect)
(Cost varies depending where you get your vinyl, this Wraptivo is an awesome product but it costs)
This was my last spare bezel i had lol now idk what to do with it, might just sell it still debating it... :gotme lol
300ZXttZMAN
Doesn't look to bad but we don't have a very good quality picture to go off of though. ha.
Maybe Canadian Booster would want this.
andre1038
2012 M56s
1996 Infiniti G20
i already got a guy who pm'ed me but hasn't responded back with his address. I will post a better picture, in person it looks pretty sweet not gonna lie. do you things i should do a write up on this? or is the video i sent self explanatory
andre1038
2012 M56s
1996 Infiniti G20
Better quality pictures
nix300zx
Car: 1990 300zx tt
I think it looks great. Im interested in it. Mine is cracked and need a new one, plus I have a carbon hood too :biggrin:
andre1038
2012 M56s
1996 Infiniti G20
nix300 sorry but fearspect already PM'ed me for it so sorry :/ if you would of sent me a messaged me earlier i would of gladly sent it to you.
Before i send it out im going to finish wrappping that small black panel that covers where the screws go in the middle
nix300zx
Car: 1990 300zx tt
I can't pm yet, but its ok. You doing a write up? I have thought of doing some wrappings too
andre1038
2012 M56s
1996 Infiniti G20
If the demand is there yes willing to do a write up :)
I have to send this one out to fearspect since im already finished with it i also wrapped the little center panel where it covers the two screw so yea. its not hard at all just very time consuming if you want it close of being perfect
Will do the write up with my Bezel from my car since i want to do it next :biggrin:
Fearspect
Car: 1990 Nissan 300zx TT 2+2
It really looks beautiful.
andre1038
2012 M56s
1996 Infiniti G20
Fearspect sorry about the wait trying to find a box that this and the bubble wrap you requested fits in nicely. The whole radio bracket was removed from the panel to do the wrapping, that part was kinda tough lol not gonna lie but i will probably provide a write up with pics on how to take apart the radio bezel without breaking it. :)
Fearspect
No rush, I'm planning on doing all my winter work on this car in March, as Canadian roads prevent me from safely driving my car to the shop for now!
nix300zx
Car: 1990 300zx tt
I would like a write up, even just a brief one. I'm going to do my bezel soon and possibly my cluster as well. Any tips or things to look out for would be awesome!
DankZX
Car: 1991 N/A 300ZX: Few Mods
1996 Sentra GXE
Yeah, go ahead and do a write up and they can put it on the website for others to use. I would be interested to.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
DankZX wrote:Yeah, go ahead and do a write up and they can put it on the website for others to use. I would be interested to.
This.
Rager
Car: 1992 Nissan 300ZX 2+2
1999 Nissan Sentra
2004 Chevy Silverado
i think you get free nico shwag for doing a write up as well.... ask mark :gotme
Ace2cool
I can confirm this.
andre1038
2012 M56s
1996 Infiniti G20
Okay guys im ready to do a write up :) with pictures!
Im going to try and see if i can do a write up tomorrow after i get out of my classes at college at 1. Will try to post pics by thursday night but no promises. If pics come up i will change the Title to Radio Bezel Vinly Wrap D.I.Y w/Pics
I already finished another one lol (but that one was for my car) so i will do the write up on the last spare radio bezel i have (which is still fully assembled with the Bose cover and everything) I'm doing a step by step that is simple yet effective. The first time you do this you will be nervous on messing up which is normal but with practice you get it down just like anything. The RHD i did came out good for being my first time doing this but i will admit i messed up on some spots but very hard to notice mainly because the material i had was somewhat forgiving on letting me redo it. I think its a cool interior upgrade especially if your interior is gray/black. Idk how it will look with someone with a tan interior though...
nix300zx
Car: 1990 300zx tt
Thanks in advance! Can't wait to read it and try it myself
andre1038
2012 M56s
1996 Infiniti G20
Ok finished taking the pictures and finished actually doing the bezel. I am gonna let the pics load into my computer over night and probably write the D.I.Y tomorrow. I'm tired lol plus gotta work tomorrow at the dealership so yea it will go up very very soon k guys :)
andre1038
2012 M56s
1996 Infiniti G20
D.I.Y almost done just gotta upload some more stuff but about 85 percent is up. Will finish it this weekend goodnight guys ZZZzzzzz lol
