Caplax40 »
https://forums.nicoclub.com/caplax40-u28573.html
Sat Dec 31, 2005 12:25 pm
I've been working on a '92 SE-R for a little while now. Here's the newest issue, and it's baffling:
I had the car up on ramps to clean out the throttle body and got the speedo cable all nice and hooked up. I fired up the car, and it ran beautifully and kept it on till it warmed up to normal running temps.
So I decided to take it for a test drive to make sure that the speedometer worked. I turned off the car, ran and got my jacket and then fired her back up and rolled it off the rampstands. And it just died.
So I thought maybe it was a fuel problem. I hadn't filled it up since before the new engine was installed, so I added two gallons of gas. No go. It cranks, but won't turn over. Fuel pump is working. I don't get it.
Any ideas?
