yodawill2000 wrote:Just look for a good quality 6X9 1 Ohm speaker ..
yodawill2000 wrote:If its a 1 ohm 6x9 I would think its compatible
There's no reason to look for a 6x9 that's 1ohm nominal. For one you're not going to find one, two it's going to be very expensive, and three a normal aftermarket speaker would work just fine. It's a misconception that you can not use a higher ohm then OEM speaker with the bose amps. Doing so will cause absolutely NO harm to the amps. In fact, they will last LONGER do to the reduced stress and lower operating temperature.
I recommend a pair of infinity kappa 6x9s for the rear
