Bizarre for an s13??
EpicFail1423
Okay, so i've been looking around online for a while and finally found some wheels that I like (as a temporary setup until I can get this project underway).Now, I'm gonna be running stock calipers on a base model coupe some caliper clearance isn't much of an issue as a foreward.Anyway, the wheels are 15x7 0mm offset in the front and 15x8 0mm offset in the rear.My main questions are the following:-What size tires should I be running on sportline springs (noted for sidewall size)-Would I need any spacers to clear the nearly stock suspension?-Is it blasphemy to put cragars on an S13???
I'm not really into the big diameter wheels but more width=more traction and I can dig that.(Thats for all you picture fiends and everyone smarter with this stuff than I)
discosteak
Car: 240sx
heres mine 15x8 cragar soft 8's
SmithSR
Car: 240sx
EpicFail1423 wrote:Okay, so i've been looking around online
EpicFail1423 wrote:more width=more traction
EpicFail1423 wrote:EpicFail
Hold on, I've got a picture
AZ89two4Tsx
slydewayz503
Car: 91 240sx-drft whore
97 240sx-daily beauty
discosteak wrote:heres mine 15x8 cragar soft 8's
Hey "discosteak" what size bore is that on your rims? my brother has a set of these wheels but the bore on them is bigger & just curious if you are runnin hub centric rings or if your just running the wheels with a bigger bore size, someone pls PM me if you guys have more info thankz.
