Bistributor, coil,
Jaywoo
Car: 1994 nissan d21tru k
I have a 1994 nissan d21 and had to repair the positive and negtive wires. Now it starts fine but when I drive it it cuts out as the rpm's go up. Why would this be.
Adverse Effects
Car: 1987 Nissan Navara 2WD 2.4L Z24
Base Standard Cab Pickup 2-Door styleside
5 speed manual
umm there is like 200 positive wires and about 20 negative wires in a car
Jaywoo
Yes, I repaired the positive and negative leading into the coil. I plugged the wires in on the opposite sides leading into the coil then corrected it when it would not start correctly. Could I have damaged the coil by doing that and trying to start it. Also the wire the leads to the coil from the distributor gives a sharp shock at the distributor. That how I found the bad wires while trying to resolve that problem
Jaywoo
Jaywoo wrote:I have a 1994 nissan d21 and had to repair the positive and negtive wires. Leading into thee coil. Now it starts fine but when I drive it it cuts out as the rpm's go up. Why would this be.
